Uncle Dave
- Joined
- Jun 10, 2003
- 240
I have an 1986 Sylvan 21' offshore cuddy. Holes have appeared in the hull. After much work removing everything above deck I finaly have removed some of the foam. Water had gotten between the hull and poured foam. Oxidation is eating the hull and ribs.<br />With some advice the repair may be possible. Maybe not. Several questions if someone would be so kind as to offer some advise. Perhaps you have seen this before?<br />1. Is there a product that will remove/neutralize the oxidation?<br />2. If the damage is not too extensive ( have not removed all foam yet) and the oxidation is removed and all holes patched is there a paint or sealer that will prevent future oxidation? Water will probably find its way back in.<br /><br />If you have experienced this on a foam filled hull, any advice on repairs would be appreciated. The boat and motor are in excellet condition otherwise.<br /><br />Thanks,<br /><br />Mr. Fitz operater of Miss Fitz
