80's inline 6 90hp "tower of power"
It has a 15" pitch stainless prop on it now. I went to put on a 17" pitch, larger diameter, aluminum prop that I have laying around and the stepped part of the prop's hub hits the gear case. If I had a second thrust washer for a spacer it would fit without hitting. Is this ok to do or is there a thicker thrust washer available?
I think the aluminum prop came off of a mercruiser.
