Check the Simple repair gone bad - Damaged housing. I managed to damage the cast alumininum upper housing where the Shifting rod enters from the upper housing into the lower unit. While re-installing the lower unit of my Force 120 ('96), I did not realize that the Shaft of the gear shift (poor choice of words) did not line up with the upper shaft and punched a hole in the housing the size of a half dollar. Any suggestions on how to repair. Can I epoxy the two broken piece in place??? Any ideas would be much appreciated???<br /><br /><br />Thanks,<br /><br /><br />------------------<br />trophyman
