Re: Aluminum "riveted" boat problem
Put somewater in the boat and mark the leaking rivets then rebuck them, would probably take a buddy on the outside of the boat btu it is really easy.
A big steel hammer and a smaller one is all you need, have someone hold the big hamer against the rivet outside the boat and smack it on the inside, leak gone.
Gluvit is a fabulous product from what I have heard but in my opinion it is a band-aid fix if you don't rebuck first, if you do both(rebuck then seal) it will certainly be a dry hull.
Buy the way, I have an '81 riveted v bow Sea-Nymph that doesn't leak and I have never touched it so they do exist.
