Re: Aluminum splashwell drain tubes
I have seen the aluminum tubes at Boatersworld but opted for the brass style you can get at most marine stores. I read a post on this forum about using a bottle jack to hold it in place, cutting length to 3/16" longer then 2 sizes of ball peen hammers to flare. I tried that last night and it worked awsome, the finish looks perfect.
The trick I found was to measure and mark tube for cutting and for position in hole then remove and cut with a cut off wheel in grinder. I also used Lepage's Bulldog polyurethane at $5 a tube versus the $20 a tube 3M 5200.
