Re: Aluminum Tracker Repair/Alumalloy
I've used Alumalloy rods for repairs on various items, but it's tricky and requires a good feel for the right temp. The work has to be super clean as well.
I'd probably opt for a good epoxy for just a leak, unless you can see a structural crack opening up.
A buddy dumped his jon boat out the back of this truck on the road, I was able to weld up the gouged, and worn away seam at the transom to boat bottom but found it impossible to make it 100% water proof. I finally gave up and brushed on some gluvit and repainted it. That was several years ago and it gets used weekly.
