I am trying to think ahead here a little bit. I am going to have to do a transom repair this fall and when looking at the cobbled up mess that the PO did to the transom, it looks like I might have to replace the entire outer skin. What is the suggested aluminum grade and thickness for the transom? Would aluminum diamond plate work? I will be replacing the wood as well with exterior ply that has been sealed in epoxy. There are bucked rivets all around the perimeter to hold the transom to the sides, etc. Can I just use pop-rivets (with 5200 sealer) to re-attach?
