Re: Am I in the zone?
5000 to 5500 in 1978 yes...when we had good, quality fuel...not the case today. We've found by experience that most all of the 5500 Max rated engines will last much longer and have much better efficiency (fuel milage) if we prop them for atleast 5800RPM. Anything under 5500 is considered lugging by todays standards and combustion temps are higher than intended and so is the fuel consumption.<br />In most cases, unless it's a new boat with a newly designed hull, your results with a 19SS will drop your RPM by somewhere around 100. It would be in your best interest to maximize with a 17P and get the R's up where they should be....<br />Many people have been through this on this forum, and those that followed the recommended set-up, found out they were very happy with the results.<br />Adding pitch does not mean you will go any faster...infact, at the RPM you are at now, your speed will likely drop.
