Am I ordering the right part#
Dry Diver
CharlieB
Re: Am I ordering the right part#
OK, I'm also confused
Checking the Merc site
http://www.mercruiserparts.com
with your model and serial it looks like a 4 cyl 40 HP
http://www.mercruiserparts.com/Show...543&bnbr=190&bdesc=GEAR+HOUSING+(DRIVE+SHAFT)
using the Merc kit
46-77177A3 WATER PUMP REPAIR KIT $95.90
When I plug the Merc # into the iBoats Search, it comes up with
http://www.iboats.com/Complete-Wate...0901148--**********.144544140--view_id.173881
18-3324 Sierra Kit
Looking in the Sierra Catalog
http://www.iboats.com/Mercury-Upper...0901148--**********.144544140--view_id.271500
with your Model and Serial
it shows
18-3507 Sierra
I found the break down of the Sierra Kit 18-3324
Which shows the pump housing and impeller #'s to be the equiv of the Merc #'s
Verify your serial #''s , and if your motor is the 4 cyl then I'd go with the
18-3324
Dry Diver
I think that I got it figured out.
I am looking for the whole kit. I think that it will be 18-3323.
Any thoughts?
I have a 2 cly, 2 stroke 40 HP.
CharlieB
The 18-3323 and 3324 are both a molded upper housing with a stainless 'cup' liner.
Have you dropped the lower unit off and seen the water pump?
I expect you to find the smaller model with the top half of the pump to be stamped out of stainless steel, not molded plastic with a stainless liner.
Not knowing the # cyl's I was looking at 4 cyl motors. Wrong.
See the Merc pages
http://www.mercruiserparts.com/selectSerailRange.asp?doc_nbr=40+(2+CYL.)
Your serial # is in the range
9854537 THRU 0P016999
then select 'gearcase' to see the water pump
http://www.mercruiserparts.com/Show...GEAR+HOUSING+(DRIVE+SHAFT)(2.00:1+GEAR+RATIO)
821354A2 W/P REPAIR KIT List $53.10 On-line $49.12
Plugging this part # into the iBoats part Search comes up with 'Nothing Found'
Call Sierra 800-723-1123 and ask if they have the correct kit for this Merc #
