roger3645
- Joined
- Aug 30, 2005
- 271
I am currently looking for a 115 V4 Evinrude or Johnson. I am currently running a 1989 90hp Evinrude, with 120 psi on all four cylinders. The motor runs very good. However; the boat is rated for a 115 and to be honest, I want to go faster. I am using 120 psi as an indicator of how good the motors are. I ‘ve read on the post on Iboats regarding the 10% rule and compression needs to over 100 psi. So, I am not looking at motors with less than 120psi. I’ve found a 1990 Evinrude 115 hp, with compression between 110 and 115 psi, for $1000.
Am I putting too much value on engine compression?
Thanks
16ft Sprint bass boat
Thanks
