Amine Blush
sanssouci
Amine Blush
....and removing it.
I'm at point right now with my redo on the bottom finish where I have to remove the dreaded amine blush. The last time I did the bottom the keels were not installed so removing was a lot easier. Does anyone have a good method to get into the junction where the keel meets the hull so the blush can be removed ?
Prairie Bouy
Re: Amine Blush
Amine blush is water soluble so that, a scrub brush and some elbow grease should fix you up.
Here is some info from West Sysytem epoxy "http://www.atlcomposites.com/pdf/west-amine_blush.pdf"
Hope that helps some.
Al
sanssouci
sanssouci
Re: Amine Blush
The bottom paint has been sprayed on.
Now to remove the rest of the masking tape and install the brass runners on the three keels.
Then flip it over in about a week, then reinstall all the top parts I took off.
Ready for this summer.
