amount of oil AQ125A takes
trebor0301
I want to change the oil in my boat but I'm not sure how much oil the motor holds.I have asked some people about it and get different answers.I am ordering a book but I would like to get going on this project now.If anyone can tell me how much with a filter change I would be very greatfull.Thanks
Dunaruna
Re: amount of oil AQ125A takes
Hi Trebor, <br /><br />with filter, 5.2 qts. Thats an approximate out of the clymer manual.<br /><br />Aldo
Don S
Just head to the boat with 6 quarts of oil. and start checking after 4 quarts are added, and then if you need 5 after running and checking for leaks add until you are on the full mark. (Don't overfill) Save the rest of the oil in case you need it while out on the water.
waterone1@aol.com
I'm with Don on that one. Exactly how much new oil is needed, Depends on how good of a job you did of getting the old oil out. A spec will tell you how much a new engine holds. Follow Don's advice and you will be fine.
trebor0301
Thanks everyone again for saving me a lot of trouble.I really appreciate all the help.
