Amps
turkey22
81 Amps Total Output/ 25 Amps Net Dedicated
This is what my 90 Etec stats are
So does this mean it should power my light with no problem and not pull on my battery while engine is running? (If hooked to crank battery)
Does this mean that my cranking battery would be ok to hook light to if?
Light has a 5.5 amps draw
85% of use will be while running the boat engine
JoLin
Re: Amps
Yes. You're good.
Works the same as the alternator in your car. With motor running you're generating all the charge you need to keep the battery topped up while you run electrical accessories.
