amps
becron
I have a minn kota fortrex 80# us2 52" shaft i am still hooking it up to my pontoon boat my question is i can't find how many amps this thing draws ,i havent bought the batteries yet it is 24 volt i just trying to figure out which batteries to get with the best amp hours with out braking the bank them thing are expensive. Thanks
MH Hawker
Re: amps
Well being as its 24 volt you will need 2 battery's and depending on how much you plan on using it that sort of dictates what group rating. Their 3 a 24,27 and 31. think of it as light, medium and heavy duty.
Star
Re: amps
Walmart has a 29 deep cycle on sale for $82 it s a no brainer!!! Bigger is better.
Davem3
Re: amps
180 to 200 is the lowest i would go, if you series 2 12V batteries, you will double the amp hours ............
mine is a 185 amp hours rating so it would become 370............ remember you need to either use a 24V charger, with sleep mode, or 2 12 volt battery chargers, but isolate each battery when charging ...............
looking at the Minn Kota site, they recommended a 3 bank, 45 amp battery, not cheap...........OUCH!!!
becron
Re: amps
Thanks for knowledge ,Walmart has 29hm 115 ah ,but i was also looking at sams too they have some DC batteries ,oh and i do have a noco 3 bank 30 amp charger from what i have gathard so far is that the 30amp charger will work for overnite .
