Amsoil??
skier
I am using Amsoil lube in the lower unit and it works great. My question is about their 2-stroke oil. Their web site says that unless you are racing to use 100:1. Does anyone else use this iol at that ratio? Should I just ignor this and use it 50:1? If indeed I can use it at 100:1 then it is about the same price as the QuickSilver oil and at 100:1 it shouldn't smoke at all. Thanks in advance for your comments/help.<br /><br />Happy boating<br /><br />Craig
flatskiff
Re: Amsoil??
Goto to their product info page both of their 2-stroke oils are reccomended for air and water cooled engines. Their both reccomended for tc-w3 use. This is both of their 2-stroke oils Here's what they say:<br /><br />100:1 PRE MIX<br /><br />APPLICATION RECOMMENDATIONS - ATC 100:1 PRE-MIX<br />AMSOIL Synthetic 100:1 Pre-Mix 2-Cycle Oil (ATC) is recommended for all water-cooled and air-cooled pre-mix applications. A mix ration of 100:1 is recommended for normal duty service in applications such as motorcycles, outboard motors, snowmobiles, weed eaters, lawn mowers and chain saws. For "severe service" applications, richer mix ratios of 50:1 to 80:1 are recommended. These include racing motors and hot operating workhorse motors that continuously run for extended periods of time.<br /><br />AMSOIL Synthetic 100:1 Pre-Mix 2-Cycle Oil is recommended for all pre-mix applications specifying TC-W3, API TC, JASO FC and ISO EGD. It is recommended for use with gasoline fuels only, and is not recommended for oil injection systems.<br /><br />Outstanding Low Temperature Performance<br /><br />Both AMSOIL Synthetic Injector Oil and 100:1 Pre-mix Oil mix readily with fuel even in low temperatures. However, AMSOIL Injector Oil with its -45°F pour point and SAE #4 miscibility and fluidity rating, is better suited for severe cold. It is recommended for use in injector systems as well as 50:1 pre-mix. Also, AMSOIL injector oil will help ease starting because it does not solidify or get gummy in the motor which allows it to turn over more freely.<br /><br />SERIES 2000<br /><br />Applications<br />AMSOIL Series 2000 2-Cycle Racing Oil is recommended in air or water-cooled two-cycle motors where NMMA TC-W3, API TC, or JASO FC oils are specified. It is excellent for both racing and recreational use in snowmobiles, outboard motors, personal watercraft, motorcycles and ATVs. AMSOIL Series 2000 2-Cycle Racing Oil is not recommended for use in aircraft or for use with nitromethane or alcohol fuels.<br /><br />Recommended for use at a 50:1 mix ratio or as an injector oil for both racing and recreational use. Also recommended for use in all oil injection systems. Recommended for use with catalytic converters.<br /><br />Keeps Engines Clean<br />AMSOIL Series 2000 2-Cycle Racing Oil contains additives that have been tested and proven to provide superior cleanliness in both air and water-cooled motors. AMSOIL Series 2000 2-Cycle additives inhibit the formation of deposits in the ring grooves, in the combustion chamber and on the exhaust power valves. With AMSOIL Series 2000 2-Cycle Racing Oil rings do not stick and spark plugs do not foul from carbon deposits, and exhaust power valve maintenance is minimized.<br /><br />Compatibility<br />AMSOIL TCR is compatible with TC-W3 lubricants and most other two-cycle oils. For best performance, cross contamination should be minimized<br /><br />For more info goto their web site or call them.
ralph
Re: Amsoil??
I tested every two stroke premix oil I could find when I had an ultra-light airplane. Amsoil was far and away the easiest starting and cleanest burning. I had a Rotax 447, a two cylinder 50 hp engine. However, I used it at 50:1.
flatskiff
Re: Amsoil??
Their series 2000 say not reccomended for use in aircraft. I wonder if it's cause of the altitude or AV gas?
skier
Re: Amsoil??
I sent a question to the Amsoil company also and am waiting for their reply as to weather they will stand behind it if they tell me that I only have to use 100:1.<br /><br />Their site is not clear on what is concidered "heavy duty". Is waterskiing? Is running at WOT for lets say 30 minutes or an hour?<br /><br />Craig
crab bait
Re: Amsoil??
i've using amsoil since start of this boat year.. i have a 40 hp nissan injected. i really don't know if i have the rite oil but it runs better then ever .. no more mph or anythin',, but incredible low idle & ditto trollin' speed , like all day long & i mean,, all day long.. MERC 140 : what's so good about there lower gear oil ??
skier
Re: Amsoil??
I gained about 150 rpm's at WOT with Amsoil's lower unit lube ;) <br /><br />Craig
