Nope it's a fuse....
working my way through a bunch of potting under that piece.
You know what....that could be a shunt. It would be a component that has all of the charging current flowing thru it, but has a precision resistance value that allows the circuitry in the reg/rect to measure the voltage across that device. That way the reg/rect can determine if the charging rate is low or high, and adjust itself if necessary.
How many wires going to that thing? If you have two small wires going back to the circuit board, one wire on each side of this thing....I would bet shunt.
Yeah mine wasn't loose connections(new battery cables) and it has a new water pump in it.Just bought this motor and really don't know the history.Just want to make sure nothing is plugged up in the block anywhere before I slam a new reg/rec in it.2 things kills em....1) is weak water pumps... the water in block doesnt cover the heat sinks and internal components overheat.....2) wing nut/loose connections on battery
Weird....All I know is my motor's VR, and that one is aluminum....I wouldn't expect a water cooled VR to be steel....yikesGee, I replaced an OEM VR with a CDI version. The casing on the CDI unit rusted away in a couple of years, causing failure. I went back to an OEM unit. Never expected corrosion failure....
