I resorted to using the hydraulic cylinder/block of wood pressure to remove the upper end after other attempts (wedges, come-along) failed to move it any more than 3/8". Look what happened.
I suppose the retaining ring, laying separately, was between the ripped out piece and the gimble bearing??
Is the hole on top of what used to be retaining the gimble bearing a set screw??
Can I just remove and repair my old transom plate if that is a set screw??
thanks for any replies. I did some searching and have yet to find the gimble bearing being ripped out like this
