Anaerobic sealant
EZSteury
I waiting for some parts to show up here and I got everything cleaned and ready to assemble when they do for My 84 evinrude 35hp, I was told to use the anaerobic sealant when I put the crankcase together and the HG as well, I went to Advance auto, Autozone and TSC but no one has it is there something else I can use or if not, where do I get this stuff?
Found one place on line that wants $49 for 1.6oz of the stuff, is it really that expensive?
Thanks.
boobie
Re: Anaerobic sealant
I've always used Loctite Gel-Seal II on the crank case halves. NAPA should have it.
EZSteury
I found it at another advance auto but they don't have the "surface prep reactor" spray and by what I read from the permatex website I do need it, correct?
boobie
The prep is if you want it to set real fast. Clean the surfaces real good, put it together and let it sit 24 hrs.
EZSteury
Thank You for this information,it is a relief to know I don't really need the other prep stuff. I really don't need it to set fast I want to put it back together and then I will be on vacation for a couple of weeks so I hope that is enough time for it to set.
Davee3
So is it best to put 1/2 on each piece or all on one - I thought maybe the prep called for on one surface helped the spread as you bolt up?
A 1/16" bead of sealer is ample.----------You want most of the sealer to squeeze out so that you get a metal to metal fit.----The metal to metal fit is important for proper bearing " clamp up " when torqued.
