AGENT 37
- Joined
- Mar 2, 2007
- 319
I've got a Yamaha analog tach in the boat now that I believe is malfunctioning. It operates smoothly and is accurate at low throttle settings but when I get up over 3500 it gets erratic and when I put in 3/4 throttle it shoots up over 7000 and dances around. Pole settings are right. I tried different positions and it acts the same except for the obvious difference in RPMs obtained by changing the pole setting. I rigged in a generic faria outboard tach and only the back light would work on it; no RPM indication. I'm assuming that tach is bad. Anything else to check before I go buy a new tach? All connections are good and clean.
