Anbody know of the best place to get a new outdrive (and not spend an arm and a
Alrighty... Looks like I will be just getting a total new outdrive for my 93 Mariah. I'm looking for an Alpha 1, Generation 2 outboard. <br /><br />Anybody have any ideas as to the best place to find one that isn't going to totally break my pocket book (I will also be taking it in to the local boat shop to have installed... so they are going to rape me on labor fees!). <br /><br />I've tried ebay and found them around $1,200. <br /><br />Thanks again for everybodys help... It's been to long since I've had my boat on the water and I miss the lake!! :) :cool:
jeff13601
Re: Anbody know of the best place to get a new outdrive (and not spend an arm an
Have you checked to see what it will cost to get yours rebuilt? An entire outdrive is going to cost a lot of cash
waterone1@aol.com
Look here on Iboats, or try www.sterndrive.cc
I might try to just take the outdrive (It's already off of the boat) into my local boat shop and see what they will charge me to just fix it... I'm hoping it's just the two upper unit gears and nothing else!
tommays
i saw your pictures that drive is going to cost way more to repair then replace<br /><br />remenber all that rust you see in the upper is down in the lower you just cant see it yet<br /><br />you have sterndrive cc for aftermarket<br /><br /><br />and a place like doug russell gets 2495 for a NEW merc drive and will give you a value on your core<br /><br />tommays <br /><br /><br />
Originally posted by tommays:<br /> i saw your pictures that drive is going to cost way more to repair then replace<br /><br />remenber all that rust you see in the upper is down in the lower you just cant see it yet<br /><br />you have sterndrive cc for aftermarket<br /><br /><br />and a place like doug russell gets 2495 for a NEW merc drive and will give you a value on your core<br /><br />tommays <br /><br /><br />
This is the post that I didn't want to read! But I had an idea that there was more damage then the two gears (They were stripped out pretty bad, and metal shavings were everywhere!)<br /><br />SO that is why I was going to just say "screw it" and get a whole new outdrive. .... :( <br /><br />How much do they give you for a core exchange?
The gears (#'s 23 and 24 in this diagram) were what were stripped out. <br /><br />
tommays
just google doug russell its one of many places you may do well at a place closer to home<br /><br />your going to have to talk to them your case looks good but who can tell were that rust stops on the shafts<br /><br />so far everybody that did the the sterndrive cc has given good reports<br /><br /><br />tommays
Don S
Just to reinforce what tommays said about the complete drive.<br />Just pulled the top off one today that looked the same way as yours. NOTHING salvagable in the lower. With the shafts, shift mechanism, all the bearings all the gears, you can get a new drive cheaper. Even from Mercruiser.
