so I want to replace my anchor light with an LED bulb. The current bulb has 2 little bumps on the metal case (at the same level) and the two metal(solder) bumps on the bottom are positive and negative.
I ordered an LED bulb on the net that looked the same, but the bumps on the side are at different levels (to not put it in backwards) and the two solder bumps on the bottom are high/low and the casing itself is the ground. So it was the wrong one.
What is the number for the first bulb described. thanks
