Mark42
- Joined
- Oct 8, 2003
- 9,334
Making a small anchor pulpit to hold a #8 Hooker brand (Danforth style) anchor. The parts are as follows: The anchor is 24" long x 18" wide and weighs about 10 lbs. The board is mahogany 3.5" x 1.125" left over from a outdoor deck project. Its heavy, solid, and more than strong enough to hold 10 lbs of anchor on a pounding sea. Also, two Attwood side style navigation lights are needed to replace the original center mounted light, 4 feet of 1/4" stainless steel anchor chain with two shackles, and a stainless anchor roller (16' long x 2.5" wide).
The pulpit will be through bolted to the bow. The entire area in front of the hatch has plywood (5/8" I think) laminated underneath so through bolting will spread the load out nicely.
I'm wondering about the mahogany being a good choice. Was planning on coating it with two coats of epoxy resin (I already have the epoxy and want to use it before it goes bad). But I'm not sure if the mahogany is too oily a wood for epoxy to make a good bond to.
Think the mahogany is OK to use or should I just go with plywood covered with epoxy/glass and paint it to match the boat?
