Anchoring an islander?
giantloop
So I have got to ask, any problems getting out on the front of an islander to anchor it? Like breaking the to down our is the bracing ok. I am looking for a boat and just wondering. Thanks
airshot
Re: Anchoring an islander?
I climb out on the front deck all the time and never had a problem. Have to be very carefull when the waves are rolling, but deck is well supported on the Islander.
Airshot
Golden Arrow II
Climbing out on the bow isn't a problem as far as structure. Like airshot said you need to be carefull, the boat will tip to the side you are climbing on and more than likely have some water spray on it and will be slick. Then having to go back while holding on to the anchor dripping water and with one less hand.
What I do if I'm out fishing for perch and know that I will be moving a couple of times is, hook the anchor line to the bow eye and then hook a tag line that is about 15 foot long to the anchor line. Tie off the tag line to a cleat in back and then toss the anchor. When its time to move I pull on the tag line while I motor forward until I get the anchor line in my hand. Then I take it out of gear and pull it in. I put the anchor in the boat and then secure the anchor line so there is no slack in it. Then I will move and repeat as many times as needed, that way I only have to go out on the bow twice. Once to hook and once to unhook. I keep the anchor in a plastic bin when moving spot to spot as to keep down on the mud and muck that gets on it from getting all over.
Pugetsound
Go on the web under---- LeeLock Anchor systems --- There in Bellingham Wa.----- I have a bow mounted one as well as most Bigger Aluminum here on the west coast . No need to get on the bow to use, a bit pricy but them how much is ones life worth ? Pugetsound
giantloop
Great info guys and much thanks again. I like the tag line deal and that anchor system looks great also.:)
