capslock118
- Joined
- Apr 27, 2009
- 249
The issue occurred on a mercury engine but I wouldn't say this issue is mercury specific so I posted in the general forum.
During my spring tune-up I went to replace the anodes on the engine. I've owned the boat for 2 years and never replaced the anodes (1990 boat). It looks like the trim anode had not been replaced in years. Oddly, the trim tab anode looked fine.
Anyways as I went to install the trim anode i found out that the bolts from the old anode had broken some time ago and now half of the bolts on each side is stuck inside the threading of the anode mount.
I tried to use a screw extractor with no luck and the threads look terrible anyways; as if no threads even exist.
I am going to speak with my local mercury repair shop and see what they have to say. Before that, I am wondering if anyone here ever came across this issue before and what you did to resolve it?
I am thinking at worst they will have to extract the bolts in some way I cannot and then use a tap and die set to set new threads in the mounts and I will just have to use large bolts next time around.
Note, this is the anode that goes under the trim block that makes the engine trim up/down, not the trim tab that is mounted just above the prop.
I doubt it would be safe to put the boat in the water before this get's fixed? I have the boat sit in a slip all season.
Thanks for your input.
