Anode plate 50HP 3Cyl 1989.
jimchere
Re: Anode plate 50HP 3Cyl 1989.
The anode plate holds a "sacrificial zinc anode." In short, the anode corrodes instead of your outboard, particularly in saltwater. It prevents galvanic corrosion. You should have a zinc on it, looks like a dark grayish piece of metal. If its missing or has been eaten away, you need to replace it.<br />Edit: Replace the zinc itself, not the whole bracket. The zinc bolts onto the plate. They're pretty cheap.
Keith Buchanan
Cheers Jim, after looking at this I could not see any mechanical reason so I had to ask why it was there.<br /><br />Regards Keith B...
