Anode replacement with Mercathode
Onexl85
Hey yall!
I have a Sundancer with dual 5.7s and alpha gen 2 drives with Mercathode. Is there a special kit that doesn’t include the anode where the Mercathode is mounted
achris
More fish than mountain goat
A kit to do what?
The Mercathode just mounts to the hydraulic trim line manifold.
Onexl85
All anode kits Ive seen include the anode that mounts where the mercatode is in place. It’s not needed
achris
The only way is to buy the anodes you need individually. Anyway, the Mercathode kit, if set up correctly negates the requirement to replace anodes. That's what the Mercathode is designed to do. Do the work the anodes do... If you need to replace anodes, Mercathode isn't working, and you need to have it checked.
Onexl85
Thanks, they seem in good shape....I’m just so used to replacing them every year reguardless!
