Anodes for 1988 Evinrude XP 150
fattony72
Hi I am new to this forum and boating in general...I recently picked up a Champion bass boat with 1988 Evinrude XP150 ...I need to replace the annodes but cant figure out which ones to get or where to get them...any suggestions?
Thanks
Fattony
tashasdaddy
Re: Anodes for 1988 Evinrude XP 150
Part Number: 0393023
Description: ANODE&INSERT AY
Pack Qty: 1
Dimensions: 6.00 x 4.00 x 1.00 (in)
Weight: 0.20 lbs
Equivalent Parts: 0436745
or sierra 186024
ezeke
You also need two stern bracket anodes part#0398331 and screws to hold them #0321861 if you are running in salt or acid water.
These stern bracket anodes are especially important if you do not replace the anode on your bearing carrier part # 0431708.
fattony72
are these the anodes that mount just under where the motor mounts to the transom? because those are what I need...I have the one for the gear case
tony v
