Anodes
fendersfender
what anodes should i be using for freshwater (lake michigan)...i bought some on the internet last year and they still look new at the end of the season.....usually they are pretty ate up after 1 season in water.....not sure if they were zinc, aluminum, or magnesium??? what type is recommended for fresh water? thanks
sundowner205
Re: Anodes
Magnesium for freshwater
Aluminum for saltwater/brackish water.
TilliamWe
Banned
Re: Anodes
Yep, magnesium for freshwater. Quicksilver puts little stickers on them that say "Freshwater Use Only". You'll know you are getting magnesium as opposed to Aluminum if the price is about twice as high. Sorry the magnesiums are just a lot more expensive.
a70eliminator
Re: Anodes
FWIW my 18yr old Cobra still has the original anodes. I guess it's because the boat gets trailered when not in use.
mthieme
Re: Anodes
My 'Ray stays in brackish water 2/3 of the year. The horseshoe zinc seems to take most of the beating. I get about 5 years out of it.
Re: Anodes
Ayuh,.... They Shouldn't be.....
Have you tried to figure out Why,..??
Is this a Dockboat,..?? Has the marina Fixed a wiring issue lately,..??
fendersfender
Re: Anodes
Wellll...let me rephrase this....this boat has twin 800 series OMCs...it stays in the water from april 1 until mid Oct.....the first few years i had it, i had stainless props and it would eat up a set of anodes in 1 season....i have since replaced those stainless props with aluminum props and can get 2 or more years from them.......but the set i put on this spring showed absolutely no signs of wear, except for an oddball one that i had in garage (it showed some corrosion and the new ones showed none)....i cannot find magnesium for 800 omcs.....so i need zinc or aluminum...whats best??
