Anodes
Just wondering, I think my boat was set up for salt water. It has anodes everywhere on the out drive. If I'm NOT planning on using in salt water should I replace all of them or what ones are necessary? and next thing I pulled the whole out drive to inspect gimble bearing and bellows they are good. I then split the upper from lower to replace water pump. Can I install the upper and still pressure test the lower with the upper on the boat?
Re: Anodes
Ayuh,... Anodes are for fighting Electrolysis, not just saltwater...
Replace whichever are eroded...
If they're not decaying, don't worry about 'em...
A pressure test should be done on the Complete outdrive, without oil in it...
Re: Anodes
ok thanks!!! Just waiting to try to find the 3/8 16 fitting I need to pressure test. I am gonna use a automotive a/c pressure tester going to cut ends and make the fittings it has psi incraments of 5 should work for what I need it to do
