dish
- Joined
- Aug 22, 2008
- 151
Still having intermittent spark.Stator tested good for resistance and output test.Couldnt get any output current on the trigger but not that confident with the procedure.Does anyone know which wires to test together.Brown,white,purple for doing the dva test.I also disconected kill switch wires for no change.Not that familier with the 1980 115 mariner.Can the trigger cause intermittent spark?I am also reading .25 volts at the kill switch wires with the ignition on.I know i bypassed that but the spark is that intermittent its hard to tell.The bias circuit in the packs tested out fine and i am wondering what the black box that mounts to where a traditional air box would be,it has the bias wire white with black strip coming out of it.I am asking alot of questions i know but just one more,there are 3 black and yellow kill switch wires and one ends up at a little black cylinder mounted on an angle,is that some sort of trim kill switch?If any one can answer just one question it would be very appreciated.
