m2bueller
- Joined
- Apr 19, 2009
- 13
I'm in the process of gutting a 1983 Chris Craft Scorpion 168 (19'6") bowrider and converting into a center console. I've been working with fiberglass since the mid 70s so this is pretty straightforward. I will be building my own console. It will be glass over plywood.
So far I've been removing the side consoles and the bow seating area. I'll be filling in the area cutout with an underlayment of 5/8 exterior grade ply covered with 1708 mat. I will be leaving the far forward bow section for an anchor locker.
The deck is amazingly strong. There is a couple of places that they went light on the glass mat (under the original seats) that I will be laying out new decking.
I'm debating whether to pull the belly tank out to give it a thorough cleaning. This would require cutting out the center section of the deck just in front of the motor. If I go to that trouble I may cover the whole deck with ply and seal it with an even layer of glass mat. I know I'll be putting a layer of mat over the inner hull sides. When the boat was built, they sprayed a light coat of chopped glass over the foam and then planed it down to level enough to carpet over. Without the carpet it's pretty ugly.
