Still trying to diagnose loss of power on my 1976 70hp Johnson. It will go almost indefinitely in the tank at idle, but dies quicker on the water in gear. At higher rpms, it dies off quicker or dies right off if I gun it. If I back off to idle quick enough before it dies, it will kick in again and idle. I can keep it running longer by pumping the primer bulb. I've checked and rechecked the floats half a dozen times and am pretty confident they are right. My ultimate question is, since choking it (after it's warm) kills it instead of perking it up, doesn't that imply that the carbs are working properly, and that it is just not getting fuel to the bowls? And that I can rule out floats and other carb issues and look exclusively at the fuel lines/pump? Correct or faulty reasoning?
