another carb ?
d absher
i have a carb off of a 90 hp chrysler and two carbs off of a 105hp chrysler all mid 70 model year will thay work on my 1973 85 hp chrysler
jerryjerry05
Re: another carb ?
You need to measure the throat.Make sure it matches the mounting studs.
Then check the jets.
They will have a number stamped on there someplace.
The jets all need to be the same size.
What U putting them on?? More info???
Frank Acampora
Re: another carb ?
Since I tend to be a bit anal and obsessive compulsive, I have NEVER mixed and matched carbs on a three cylinder engine.
If the number on the flanges are the same, they will work well. If the numbers are not the same, they will fit but offend aesthetically. There is also the possibility of engine damage. The two 105 carbs are usually WB with a 1 5/16 venturi and the 90 is always a WB carb with a 1 5/16 venturi BUT---They are jetted differently. Try to find another 105 carb if you really want to use them
EDIT: Do not expect a horsepower gain using the larger carbs--aint gunna happen.
