RaceCarRich
- Joined
- May 31, 2015
- 234
2000 Mercruiser 3.0L
Dies on the trailer when shifted into forward.
Had problems going into gear beginning of last year. I shimmed up the interrupt switch to get through most of the season. Near end of season, I replaced the lower shift cable following instructions to the tee. All was perfect for the few times I went out before winter.
Fast forward to now, dewinterize and all is good for about 30 minutes. Change oil, etc. Go to restart, and it's starving for fuel. Long story, entire fuel system needed flushing. Just finished rebuilding carb. Starts & idles great. Dial it in. Revs great in neutral. Shift into reverse no problem. Shift into forward and interrupt switch engages. If I unplug the interrupt switch, it shifts into forward and doesn't die.
Any ideas? Adjustments (hopefully)? Can worn upper cable cause this? I'm actually looking to get rid of this boat cheap and upgrade but need to fix first.
Thanks!
Thanks!
