I want to feed a subpanel from a 200 amp service panel from a tap on the load side of the disconnect breaker. the sub panel is a 100 amp main lug type. The panels are less than 1 foot apart. I want to feed the sub panel through a 80 amp breaker in the sub panel. Will the 80 amp breaker protect the sub panel with the power flowing through it backwards? I am not concerned about the any physical damage to the wire from the 200 amp panel to the sub panel, it is in a 1' run of conduit.
