So I installed my motors yesterday.... new mounts,... rough alignment is ok, and I just had one question regarding that.....
Should the engines be perfectly level (check by putting a level on them) and then go to adjusting each side equally until the desired result
is reached.... I assume that is the case, but I just wanted to be sure...
Thanks...
Thanks...
