Another engine ID help post
lee_in_nj
Just aquired a 10 HP 2 stroke McCulloch outboard from a friend and the engine cover is missing. I need to identify the engine for this and to buy a few parts to get it running again. It does have a tag on it. Is it possible to find out the year by the serial number? There is no manufacter date, it is definitly a vintage engine. Thankyou for any help you can give me.<br /><br />Lee Cannon<br />Howell, NJ
fone_man
Re: Another engine ID help post
Need Model & Serial # off plate & I will try to ID for you...<br /><br /><br />Waiting on your reply..........<br /><br />
<br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
lee_in_nj
No model Number, just the 10 HP rating and the first four of the serial number "138A" Looks goofy without the cover on.
fone_man
H.P. Years <br /><br />3.6 1953-57 <br />3.6 1958-59<br />5 1958-59<br />6 1960-62<br />7.5 1952-87<br />7.5 1958<br />7.5 1958<br />7.5 1960<br />7.5 1961-68<br />10 1958<br />22 1958<br />25 1959<br />25 1959-60<br />28 1961-68<br />30 to 33 1955-56<br />40 1957-59<br />40 1958-60<br />43.7 1961-62<br />45 1963-67 <br />50 1964 <br /><br /><br />
Walter
Lee...<br /><br />My source says your 10 hp McCulloch model 138A is a 1959.<br /><br />Walt
fone_man
Walt...... good job<br /><br />Only thing I could come up with, so I posted all I had.<br /><br />What source are you using???<br /><br />
<br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
Walter
Fone...<br /><br />Peter Hunn's "The Old Outboard Book" revised and expanded version. It's loaded with info...<br /><br />Walt
