another floor qustion
brad1963
86 bayliner capri open bow.i want to know if i can cut 2 by 6's and use them for beams or stringers across the bottom of the hull be for i lay the floor down.i want to do this cause it will support my floor better,and if ok i would glue then to the hull and then epoxy them and fiberglass them,will that work?thank you
JasonJ
Re: another floor qustion
2x6s are overkill. You should use the dimension of whatever was used before, or like I did, use 3/4 ply. My project has six stringers, spaced from 7 to 14 inches apart though, so I have a lot of support and strength. If you use expanding foam under the floor, that will provide a lot of support and structure as well. Good luck....
