Another fuel guage question
beavers82
So, my tank was empty and when I turned the key on you could see the gauge move. Now I have no movement out of the gas gauge, and there is at least half tank. I used test light and there is power to gauge. I even tried to reground it, that did not work. Tested the pink to the sending unit, it's fine. Tried to ground pink wire to make gauge move, nothing. So now what? Take out sending unit and move it, see if that works?
achris
More fish than mountain goat
Re: Another fuel guage question
You grounded the terminal on the gauge that has the pink on it and got no gauge movement? Faulty gauge... Buy a new one...
Chris...
stylesabu
how did you test pink wire. did you check and make sure gauge was grounded? if gauge has power and ground then ground sender terminal if gauge doesn't move its bad, the gauge is bad.
