I'm asking this because I've never used gel coat..<br /><br />When using gel coat, what is it's consistancy?<br />For example, is it real thick whereas if you apply it to a non-smooth surface, the gelcoat will fill in the rough spots and will still come out real smooth? Or is it more like paint and the way the gel coat looks is the same shape as whatever you are applying it to.<br /><br />Does the surface you are applying the gel coat have to be perfectly smooth in order for the gel coat to come out perfectly smooth?
