i have 2 types of "boat trailer and marine" grease, Not that the grease will even be exposed to water..
One is Lithium complex
the other is Aluminum complex (seems thicker)
Which type does OEM mercruiser u-joint and gimbal grease use???
it says on the tube DO NOT MIX GREASES.
Also Which grease should i use on my alignment tool??? and splines when i put the drive back on??
