larky
- Joined
- Aug 23, 2006
- 304
1971 50hp 50173s
when the hood is on it doesn't exactly choke the engine it just doesn't seem to run as high of rpms. I have sprayed both the gaskets above and below the exhaust adapter near the power head with soap and water but saw no bubbles or leak. could the same symptom be caused by leaking exhaust housing seals that are near the water pump and lower unit?
I will check the hood latch in the morning to see if it's grounding the plug wires. but if it was that i would expect more of a power loss than what i experienced.
any ideas would be helpfull
