Another lower unit compatibility question
KilroyJC
This is probably a question for chinewalker...Having seen the pix on his website...<br /><br />I have acquired a 1952 Evinrude 7.5hp, model #4447, which is missing the lower unit. Will a LU from a 1957 or 1958 work with this?<br /><br />Thanks,<br />Matt M
Chinewalker
Re: Another lower unit compatibility question
Hi Matt,<br /> No, it will not. The '52 uses a spring clutch for neutral. Used on 1950 to 1953 models, which will all interchange as a unit, but may not interchange at the bits and pieces level. The later units use a full gearshift - different unit altogether...<br /><br />- Scott
KilroyJC
I knew you'd have the answer!<br /><br />I guess that in the meantime I'll work on the upper unit first & get that in shape, then try to find a lower later on.<br /><br /><br />Thanks Again,<br />Matt
