oldrudedude
- Joined
- Jul 3, 2008
- 480
1971 Johnson 100hp electric shift
I changed the type "C" fluid in the lower unit a couple of days ago and noticed the old stuff to be milky. Checked it today after the weekend in the water and noticed it to be milky again. On inspection I noticed a smudge of oil at the bottom of the prop housing just aft of the engine skeg. I am assuming the prop seal is worn and letting water in and oil out. Do I have to remove the lower unit to change it or can I just remove the prop then pop the old seal out and drive another in? Also noticed there is a wee bit of play in the prop shaft in all directions. Movement is not the prop on the shaft. That is secure. Should there be slight play between the shaft and the bushing or should it feel perfectly tight?
