Walkersteelhead
- Joined
- Mar 28, 2005
- 30
On my 60ish Pacific Mariner with either a 120 or 140 engine. The stern drive number is 2066652. As far as I and the guy before me the stern drive is the original. I replaced the solenoid on it,I tested it and it was dust. No when I click up on the rocker switch the solenoid switch just clicks. I'm thinking the the motor is locked up. But I could be wrong. I have double checked the wiring on the Soleniod and it is correct. I used a test wire jumpin the hot and same result. Is there a rebuild kit or is it better just to install a new unit. Napa wants 330 for theirs. Also where is the oem number on it.Thanks again for the help.
