cajunboating
- Joined
- Aug 19, 2010
- 8
Hey guys I have an OMC 800 (1985) 350 ci motor. 22ft cuddy cabin One more note I did put a new prop on that I ordered from here and it seemed to handle great.
Engine and lower unit all redone in 07' bought this boat a couple of months ago and have only taken it out a couple of times. Well yesterday was the first time taking it out into the river and had to tilt the motor up to make it past some points so that is why I noticed this now.
But when I run the lower unit all the way down it sounds and works great the instant I take the tilt up a bit it starts with a clicking noise while the prop is turn it does it a bit more in reverse then forward but there is still a noise as soon as I put it back down then the noise goes away.
The noise starts as soon as I'm an inch off of the all the way down position.
Thanks guys.
I'm still getting use to this neutral set up as it is a bit different not use to having to pull the shifter for neutral All my other boats I've had was just throttle back into neutral.
Thanks guys.
