I've been lurking around this site for a year now, slowly working on my boat. i hope to hit the water this season, but have a problem.
the boat has sat outside for several years in central IL, but was winterized. The motor turns over and all appears to be working. it has some rot issues, but nothign too bad. i think it will work as is, but i need it to run before i do any more with the interior.
1979 19' bowrider
OMC 800 outdrive
Ford 305, carb, electronic ignition (no points)
I got the trim motor working, and replaced all 4 solenoids (2 tilt and 2 trim), new battery, plugs wires, oil changes, fuel filter and hoses, cleaned the gas tank, etc.
But the Tilt will not engage
I've pulled the clutch assembly apart and regreased everything (it was not too bad, no water inside)
i beleive the problem is with the tilt motor, or the gear assmebly, worm gear?
this is not a hydrolic assembly, there are no hoses
I guess my question is how do i get this motor out of the boat. The exhaust manifold is in the way, and i can't find any bolts that hold this motor in place. do i need to remove the outdrive to get to the mounting bolts, are they inside the outdrive, or are the outside the motor and so rusted they don't resemble bolts anymore. i'd liek to get this working as it is the only thing standing between me and the water. i suppose i could unbolt the half moon gear and manually raise and lower the end unit and bolt it back into place, but that could be dangerous, and a pain on the loading ramp.
i know this site is full of experts, so thanks in advance for all the help.
Let's go boating.
Jon
1979 19' bowrider
OMC 800 outdrive
Let's go boating.
Jon
