I have a 1978 305 Chev OMC with 800 series outdrive. My trim motor (front of engine) was not working but when I used the trim button on the shifter I could hear a clicking in the solenoids. I repaired the 12 V and it was working fine on the bench however once installed there was no clicking in solenoids and no response from the shifter. Checked for the fuses but can't find any by the starter. Are they at the top starboard side of the engine? If so what do they look like?Took a screw driver and touched the two screws on solenoid and the motor went up/down however still no luck with the trim button???<br /><br />2. After not leaving well enough alone the 12 V wire came off in the trim motor so that meant taking the trim motor out again. After loosening the last of the bolts on the trim motor this time the engine came crashing down and now I can't move the engine up or down using the nut ontop of the housing. The bottom of the gears is only 2 inches from the bottom of the boat and there is no way to move the engine up. <br /><br />I have gone through the reviews for the past year and still can't find the answer for my situation. <br /><br />Getting frustrated......<br /><br />Any ideas....
