turret_plug
- Joined
- Jul 7, 2011
- 9
2010 Mercruiser 3.0 (TKS) with power steering..... Bought used, went our first time, alarm sounded and temp spiked at about 195-200 F after about 2-3 hours of use (At around 3500 RPM). Let it cool off, went home.
Took it to marina, had impeller replaced, T-stat replaced.
Took out again next weekend, pretty much the same condition, back to marina.
A little history though, boat has MASSIVE stereo, and we noticed an audible squeal, but not the belt, it was from actual alternator (I figure it's dying). Mechanic called and stated alternator needs to be replaced, and that it is most likely causing the belt to slip because it is seizing, and not spinning the circulating pump very good leading to an overheat condition.
They are also flushing the PS cooler and pulling all hoses to ensure no impeller fodder is lodged in the cooling system.
Boat otherwise runs very well, but I just wanted some opinions here before I doo doo more money at this cooling issue.
Thanks!
Thanks!
