Started a new one instead of dumping on someone else's....
I believe I read that porpoising can occur when the motor is trimmed out too far...and to fix it...trim it in some.
If this is true then I have a question about what happened to me recently.
River boating but pretty choppy as the wind was kicking 15-20 probably.
Started with the motors trimmed all the way in. Hit the throttle full open. Took a while to get on plane and when it did.....immediately began porpoising like CRAZY. Each upward movement higher than the last. Tried it several times in different directions to see if wind or wave direction were a factor. Nope. Did it every time.
Finally just gave up and came in slow and deep in the water (not on plane)
Info:
25' SportCraft Walkaround, twin 200 mercs mounted on platform (not transom), boat has trim tabs (helm adjustable), 60 gallons of fuel in 170 gallon tank.
I don't know the position of the trim tabs as it was my first trip in the boat and have never had them before. When porpoising occured I did push them toward the "bow down" position but it didn't help much.
So if you porpoise when the motors are trimmed out....what could have made this happen?
Want to avoid it in the future.....forever.....
Info:
